Computer Chips & Tuners
95 F150 computer code? help ken
Old Sep 1, 2004 | 04:21 PM
casca2063's Avatar
casca2063
Question 95 F150 computer code? help ken
Ok, so I pulled the vinyl trim off from around the emergency brake and bending just right with a flashlight I can see the code. I think.
What I see is 'FHTF-APC' and under that in bold print on the same lable are the letters 'HUG2'. I have 2 questions. First, Ken is the 'HUG2' the code you need to for programing?
And second, this is open to anyone, how do I get to the unit when it's tucked up so tight behind the emergency brake. Will I have to remove the E-brake hardware? Is there enough slack to just loosen everything and pull it out of the way?
Thanks
Old Sep 1, 2004 | 04:38 PM
95 F150's Avatar
95 F150
The HUG2 is the computer code, my 95 has the same code as yours. I pull my computer from under the hood, it takes me about 10 minutes to pull it doing it that way.
FTE Ken's Avatar
FTE Ken
Yes, that's the code. And yes, the emergency brake assembly will need to be moved out of the way. Instructions for that are included.
Old Sep 1, 2004 | 05:41 PM
casca2063's Avatar
casca2063
Thumbs up
Thanks to both of you.
