cool fuel
Old Sep 1, 2004 | 12:22 PM
ranchero77's Avatar
ranchero77
cool fuel
I would like to know if there are any noticable power gains from using a cool can on a carbed mild street engine.
if so are there any limiting factors to whats "noticable gains" such as comp ratio, carb size, altitude, humidy?
Old Sep 1, 2004 | 01:47 PM
beartracks's Avatar
beartracks
I don't think you could keep ice in it. I have heard of people wrapping the fuel line around the AC line to prevent vapor lock.
Old Sep 1, 2004 | 01:54 PM
ranchero77's Avatar
ranchero77
I wouldn't get the cheap mr gasket one. it has no insulation. ice would melt fast in that one.
the moroso one looks nice. its insulated with threaded inlet/outlet ports. it uses a heat sink type resivoir instead of smooth coils.
Old Sep 1, 2004 | 07:37 PM
f100guy's Avatar
f100guy
i wonder if you could get one with a drain valve to drain the old water out. i could easily modify one of those to keep the ice solid longer. if you put dry ice in there with water how much of a gain would be present, would it be enough to make the engine run smoother or make me feel a difference
