Bronco II Ford Bronco II
Removing Interior Door Panel
Old Aug 31, 2004 | 10:46 PM
Radiation's Avatar
Radiation
I am having trouble removing the interior door panels to replace the speakers on my Ford Bronco II (1990). Is there a trick to getting the window turn handle off?
Old Aug 31, 2004 | 11:08 PM
RomerB2's Avatar
RomerB2
its actually pretty easy, i have automatic windows and doors so it'll be a little different but not much, on your turn handle there should be a slot where cou can slide a flathead screw driver into it, and pry it off, on my dads ranger there was, and then once you do that, you will have to take the screw out of the handle for opening the door and there will be another screw on the handle for closing the door, u should have to look at it from above to see it, they're easy to get out, then put the screws aside and carefully start at one corner and pull out, try not to break any clips, or you can get one of those overpriced tools that release the clips so they dont break, but then you can just pick up the panel and set it aside and have a clear opening for your speaker
Old Sep 3, 2004 | 09:39 AM
Hell_Fish's Avatar
Hell_Fish
Thumbs up
The bolts that hold the window crank is a torques head I believe or maybe a allen. Remember to remove the screw from the door pull cup.
