Transmission swap
Old Aug 31, 2004 | 04:07 PM
weymouth's Avatar
weymouth
Question Transmission swap
I have an '89 F150, 4WD, 5.0, Automatic that is worth keeping.
I also have a '92 F150, 2WD, 6 cyl., 5 spd that is not worth keeping.
Can I take the manual transmission from the '92 and install it in the '89?
Old Aug 31, 2004 | 04:32 PM
acerockola77's Avatar
acerockola77
Yes, it will take some work though.
Old Sep 1, 2004 | 12:24 PM
weymouth's Avatar
weymouth
How much work?
How much work are you talking about. Will it be all wrench turning or will it entail moving/replacing a crossmember. Would the bell housing from the 6 cyl fit the 5.0L? Any Idea of the output shaft of the maunal trans, will it fit the 4WD trasfer case? If I've got to scrounge around bone yards looking for bits or having to dissect the trans, it's not worth the trouble. The '89 runs and drives nearly perfect with 80k miles on it.
Old Sep 1, 2004 | 12:38 PM
weymouth's Avatar
weymouth
How much work are you talking about? Will it be all wrench turning or will it entail moving/replacing a crossmember? Do you know if the bell housing from the 6 cyl will fit the 5.0L? What about the output shaft, will it fit the 4WD transfer case? If I have to spend time scrounging bone yards for bits or have to dissect the trans, its not worth it.
The '89 runs and drives nearly perfect with 80K miles on it.
Old Sep 1, 2004 | 01:09 PM
drewcoolness99's Avatar
drewcoolness99
lol most informative answer of the day
umm
never actually dones this but you will need to move the cross member/ or get a new one. Get a flexplate and the only thing that seems like a pain is the gear selector. oh and the driveshaft. Not sure it it will fit or not.
Old Sep 1, 2004 | 08:46 PM
andym's Avatar
andym
I don't think the tailshaft on the 5 speed is removable (I could be wrong, though) but if that's the case, then you won't be able to bolt the transfer case to the tranny. You'll need to get a 4wd transmission to do this swap.
Old Sep 2, 2004 | 07:27 AM
weymouth's Avatar
weymouth
Thanks for the info. I'll most likely scrap the idea. Like I mentioned earlier, the truck runs nearly perfect at 80K miles. Why mess with it?
