I joined to check out re-build/crate options. Very nice runing (ran) motor finally bit it due to heavy foot, (and a strong dislike for Chevy's). Will keep posted on what I do,..... or don't do.
Hello Walt. We're glad to have you here. There are a few of sections here that will likely be of interest to you. First as mentioned, the Bronco section. Also the 289/302/351w section. Also, because its the same basic chassis, the 1987-1996 F-series section. Between those three (and the other sections) you're likely to find answers to most any question you have. Good luck with the engine search, there are a lot of good crate engines available... any as many opinions on which is best!
