Basic Diesel Question
Old Aug 30, 2004 | 05:17 PM
jarmbrester's Avatar
jarmbrester
Question Basic Diesel Question
What causes a diesel engine to "rattle"? I have a 6.0 and am experiencing the loud-to-quiet-to-loud that many others are experiencing. Even when the engine goes silent, it's still running. Anyway, just curious about the cause of the diesel rattle.
Old Aug 30, 2004 | 07:02 PM
04superduty's Avatar
04superduty
the rattle sound coming from the engine is the combustion process. when the fuel is injected and ignites it makes that rattle sound.
Old Aug 30, 2004 | 07:18 PM
johnsdiesel's Avatar
johnsdiesel
Diesel ignites slower than gas. Your engine is also made a lot more stout than a gas engine, and the compression is roughly twice that of a gas engine.
Old Aug 30, 2004 | 07:25 PM
bighoss550's Avatar
bighoss550
raddle/tickety-tick sound in our HEUI diesels is mostly from the activation of the injectors.
the diesel clacking sound is actually the piston rocking in the bore and "falling" from one side of the cyl to the other as the rod center moves from BTDC to TDC and down ATDC. the fire in the hole is pushing on the top of the piston and it wants to move away from the pressure so it hits the pressure side of the cylinder.....
i know it sounds complicated, but its really not....just visualize the inner workings of the motor
Old Aug 30, 2004 | 07:31 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Good explanation
The more clicking, rattling, vibrating, whistling, and growling noises my truck makes the better, as far as I am concerned...Just lets the people around me know the beast is alive
Old Aug 30, 2004 | 11:32 PM
kw5413's Avatar
kw5413
Yeah... and for PSD that means all the moving parts are still moving...not welded togther or disintegrated...No wonder the more noise the better.
Old Aug 31, 2004 | 07:08 AM
psdwanabe's Avatar
psdwanabe
I'm far from an expert but, I would think if the diesel knock was caused by the piston doing what you describe, diesels wouldn't last as long as they do. Its my understanding that what your hearing is the actual pressure wave of the ignition process. Thats why a diesel is quieter with pilot injection, the pressure wave is less violent.
Old Aug 31, 2004 | 08:30 AM
bighoss550's Avatar
bighoss550
the "pressure wave" in a PI diesel is more violent. the cyl temp is up because of the initial pulse. it is quieter because the main injection is after TDC. it can do this because the heat in the cyl is high enuf to burn imediately.
its not hitting hard, BTW. its only a few thousanths clearance once warm.
ever herad a real race engine with forged pistons start up cold?(with mufflers) that is the same clacking sound u hear in a diesel.
there may be some sound from something else....... if the flame front is what makes the sound, why doesnt a gasser make the noise? its flame front is much faster and violent than our oil burners????
Old Aug 31, 2004 | 08:42 AM
jarmbrester
Thanks for the posts. But I'm still a little confused. The 6.0 runs an 18:1 compression ratio. I would think the engine would have to be tight to handle that kind of compression. Even if the clearance is only a few thousands of an inch, would that allow blow-by and loss of compression?
So, bighoss550, when my engine runs totally quiet, what is happening? I can unplug the EGR (see the thread on the EGR & Throttle Plate) and the fluctuation in the diesel sound stops. As soon as I plug it back up, the change begins again. Is the compression ratio dropping? Is the timing changing?
Old Aug 31, 2004 | 08:46 AM
bighoss550's Avatar
bighoss550
the timing almost has to be retarding when it is going quiet. does it smoke when quiet??
it is a tight fit when the piston temp gets high. alum expands more than steel or iron. if it was a tight fit, it would become a "press" fit once hot!!!!! thats no good
Old Aug 31, 2004 | 09:34 AM
jarmbrester
Haven't noticed the smoke. I'll watch for it. "sneeker", in this thread https://www.ford-trucks.com/forums/s...d.php?t=276702, attributes the problem to the exhaust pressure sensor. I'm going to talk to the diesel tech at my dealership about this.
Old Aug 31, 2004 | 10:27 AM
ZBeeble's Avatar
ZBeeble
I was always told it was the pistons swapping holes ...
Old Aug 31, 2004 | 10:32 AM
ZBeeble's Avatar
ZBeeble
Well... he's talking about the skirt of the piston moving a few thousands of an inch and striking the cyninder wall. It's the "rings" that prevent blow by and maintain the compression.
But seriously, I understood the diesel knock was partially due to the running gear (injectors mainly) and partially the pressure wave ... which according to some things I've read is violent enough to cause the cylinder walls to flex (which is the reason for the cavitation ... and the associated processes to prevent it).
Old Aug 31, 2004 | 11:18 AM
jarmbrester
Boy, those piston skirts must be tough! Back in my younger years I played around with a 1929 Ford Model A that had been stripped down to almost nothing. The cylinders were worn so bad that I broke the skirts off a couple of pistons.
Anyway, guess that's why these PSD are so tough!
Old Aug 31, 2004 | 12:14 PM
bighoss550's Avatar
bighoss550
ok, let me be a bit more specific....
at cold or at idle the clack is the skirts.
at hard throttle and high heat the only clatter will be the tink of the fire in the hole. which u will rarely hear.
