Part and Body Compatibility
Old Aug 30, 2004 | 09:14 AM
Dylansdad's Avatar
Dylansdad
I am new to the forum and new to Ford truck. I just bought my uncles' old 1984 F150 4x2 truck. It only has 91000 miles on it but is in serious need of some TLC.
Does anyone know what years can I swap the seat with for just a direct bolt up? Also the same for the bed.....it has some serious rust in the usual places (so I have noticed) and I think it would be better to just swap the entire bed....thank you in advance for the help and I am sure I will be back.....like I said this thing needs some serious catching up on TLC......
Old Aug 30, 2004 | 12:53 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Everything from the doors forward stayed the same from 1980-1986. The doors stayed the same from 1980-1996, except for the interior panels and holes for the sideview mirrors. The cab, is 1980-1986. You can use beds from 1980-1996, just the taillights changed a little.
Also the seats are from 1980-1996 I think, not sure about direct bolt in.
Hope this helps a little.
Old Aug 30, 2004 | 06:23 PM
big hoss 29's Avatar
big hoss 29
The seats from an 80-96 will bolt right in with no problem, as long as you go from bench to bench or buckets to buckets. If you go from a bench to a bucket seat, you might have to do some fab work, but not enough to keep you from doing it right.
As far as the bed goes, any 80-96 bed will also fit, but the lower lip of the wheel well is a little different from 87-96 compared to 80-86. It's not ugly and you have to look hard to notice it. The good thing about an 87-96 bed is that they are a little less prone to rust than the earlier models.
Good luck!
Old Aug 30, 2004 | 06:48 PM
91f250460's Avatar
91f250460
Yeah, the only difference other than taillights is that the 80-86 fender was more square around the wheel opening and the 87-91 is more round. But as big Hoss stated, it doesn't look bad. As far as wiring/mounting the bed it is the same.
T. Roberts
UFD Local 1147
Old Aug 30, 2004 | 10:37 PM
mirage820's Avatar
mirage820
I've been trying to get that info on the beds for about a month now. thanks guys. really helpful.
i'm wanting to put a later model bed on my 80 swb 4x4. does anyone know what year bed the guy in the gallery has on his "red 82 f150 4x4"?
miz
42
Oct 22, 2014 08:12 PM
floridahunny
New Member Introductions
Apr 19, 2013 12:52 PM
SANDBOX1
Feb 7, 2013 10:05 PM
cryanbishop
Georgia Chapter
Aug 23, 2012 05:37 PM
65_sleeper
Jul 21, 2005 06:06 PM
