Sponsored by: Innova
door panel removal
Old Aug 29, 2004 | 08:48 PM
bunnycop's Avatar
bunnycop
door panel removal
how do i get the door panels off of a 2003 superduty to install new speakers? thanks
Old Aug 30, 2004 | 05:24 AM
stealth1's Avatar
stealth1
It should be the same as my 02. remove the black plastic cover on the door jam, pops off. Pop up the switch panels, very simple, unplug all harnesses. Under the light cover on the bottom left corner there is a bolt behind the lens. Be careful when removing the panel as you'll have to remove the light bulb connector behind the same cover. There is only 1 other bolt, under 1 of the switch panels, easy to see. The whole panel will slide up. Easy breezy..
Old Aug 30, 2004 | 08:13 AM
bunnycop's Avatar
bunnycop
thank you very much
