390/auto in a 58 F-100
Hi All,
A friend of mine has a 58 with a tired 272 (or 292?). The truck is rust free. He also just bought a very rusty, low mileage t-bird with a 390/auto. He wants to put the 390 into the f-100. Any suggestions of where to find mounts or headers to make all this work. Also, what do you think the diff. ratio is in the truck? It had a 4 speed. Any info will be greatly appreciated.
Received 1,357 Likes
on
Originally Posted by my4848car
Hi All,
I cut the front crossmember from a 56 Ford passenger car frame, trimmed the
ends and bolted it to the y-block in my 60 (using car motor mounts) prior to pulling the y-block out in preparation for installing the FE. This allowed me to keep using the truck while I was preparing it for the FE.
Then fabricated flat plates for each end of the tube crossmember. Used
angle iron on top of top frame rail and on inside of bottom frame rail. The flat
plates were welded to the crossember and used bolts to bolt the four pieces
of angle iron to the crossmember and frame rails. The engine I used came from
a 66 Galaxie and I used all the pulleys, brackets and fan that went with it.
Used Ford alternator and hooked it up to existing truck wiring without cutting
my wires.
I had to move the radiator forward about 1 inch using square tubing on each
side between the rad. and the support. I used stock FE exhaust manifolds and
fabricated my on exhaust out of the 66 Ford pipes.
I used the 66 rear crossmember and bolted to the underside of the bottom
frame rail. The transmission I am using is a 57 Ford passenger overdrive.
Had to shorten a driveshaft.
I also had to notch the front pickup crossmember for bottom pulley clearance. and notched out for the bottom radiator hose for extra clearance.
The engine looks like it was made for the 60.
jt
my wires.
jt
