Sponsored by: Real Truck
4 wheel drive
Old Aug 29, 2004 | 05:24 PM
Harleyvette's Avatar
Harleyvette
4 wheel drive
Have noticed about 4 times now my 4 wheel winds up in high range without my knowledge. Today in a parking lot it went in when I started off. Has anyone else had this happen? 2001 F 350. Thanks, much enjoy the comments on here.
Old Aug 29, 2004 | 05:26 PM
04superduty's Avatar
04superduty
do you mean it just goes into 4wd without you knowing? is it manual 4wd or shift on the fly.
Old Aug 29, 2004 | 05:36 PM
FortyFords's Avatar
FortyFords
I'll bet you have a hub or hubs not releasing .
as 04 stated what type ESOF or manual?
Chk your hubs by crawling under and turning front axlesshafs, see if their free
rich
Old Aug 29, 2004 | 05:44 PM
Harleyvette
4 wheel drive
It has the shift on the fly. Noticed it one cwinter day when I was going about 55, have no idea how it happens. Auto trans.
Old Aug 30, 2004 | 08:21 AM
Big Orn's Avatar
Big Orn
Welcome to FTE, Harleyvette
Are you sure that it is actually going from Low to High or from 4WD to 2WD? It could be just the light or a short in the wiring.
When this happens have you tried to shift the tranny to neutral, depress the brake pedal to see if it shifts back?
Old Aug 30, 2004 | 09:53 AM
Harleyvette
Actually going into 4 wheel. Could hear the clunking or scraping when I turned the corner. Stopped, backed up after putting switch back to 2 wheel, all is fine again. Switch actually moves to 4 wheel.
Old Aug 30, 2004 | 10:57 AM
Big Orn's Avatar
Big Orn
It sounds like it could be the GEM (General Electric Module) going bad.
Maybe FortyFords will chime in and tell you more about it.
You wouldn't happen to have a slight windshield leak, would you?
Old Aug 30, 2004 | 11:18 AM
Harleyvette
slight windshield leak, lost me on that one. Had it replaced last summer, never had any water leak into truck that I know of. Small rock star chip in it now. 25000 miles on it, shouldn't wear out that fast.
Old Aug 30, 2004 | 12:35 PM
mikewrt's Avatar
mikewrt
What the switch actually moves to the 4x4 position on its own?!? sounds like you got your self a ghost or somethin!! he he.
Old Aug 30, 2004 | 12:37 PM
Big Orn's Avatar
Big Orn
The reason I asked was that if these GEMs get wet they can fail progressively over time. Water is bad enough on any electronics, but makes this thing act up.
Have you got a Haynes or Chilton's manual? It can tell you how to replace the Gem - IF it's the culprit.
If there's anything else I can't think of it right now.
The solenoid or relays wouldn't cause it, I don't believe.
