C7AE-A Heads
C7AE-A Heads
OK, hear we go. My 67 2WD short wheel base pickup is packing a 390? Block # is C6ME-A, heads are C7AE-A without the thermacter. Cam is either a 268H or 270H Comp. Have just replaced the rocker arms and shafts with OEM. Hedman headers with FlowTech mufflers. Pipes are 2.5in StreetMaster intake with a Carter Competition AFB numbered 1203. Heads have been angled and ported to match intake. I ain't interested in stump pulling cause she has more torque than I can put on the ground. More interested in quarter mile or top end. Tranny is a three speed manual changed from tree to floor with Hurst shifter. What iron heads if any would give better performance? Thank Ye!
on
1 Post
Boy you sound like a happy camper....Glad to hear it...what kinda CR are ya runnin with those heads? about the only Iron head I can think of that might be better is a ported set of C6-Rs....
Also remember more fuel and more air..bigger cam..higher stall...lower gears...and then the list goes on.....
Russ
Russ
Originally Posted by RapidRuss
Dirk, I was just on network54, and there's a set of C6-Rs for $150 if you might be interested???
Russ
Russ
https://www.ford-trucks.com/lc/lc.ph...eid=1094073821
srsbjohnson
08-06-2013 04:28 PM
pward76
44
07-31-2009 01:04 PM
C5AE-A
09-23-2008 10:29 PM
