Aerostar Ford Aerostar
Front Windshield Defrost/Defogger doesn't work....
Old Nov 10, 2002 | 10:41 PM
DaveC88's Avatar
DaveC88
[updated:LAST EDITED ON 10-Nov-02 AT 11:43 PM (EST)]Hi everyone,
This is my first time posting here as I've just found this site, I've searched through all the backpages and was not able to find an answer/solution to my query which is as follows:
The front windshield defogger/defroster doesn't work. When I move the right dash switch from off to Vent wind comes out and depending on the temp setting it's either hot/cold as it should be. When I move the fan switch from LO to middle to HI it increases or decreases appropriately. So wind does come out strong, and the temp is right so that's fine, the problem is when I go from VENT to HEAT to MIX or to DEFROST (the little window pic) the wind doesn't cycle through, or change at all for that matter. The air just comes through the vents at every setting instead of going to the back of the dash to the front window to defrost or defog it. I do not have A/C don't know if that makes a difference or not....
My local mechanic tried putting in a new gauge switch cluster but the problem remained, he also tried replacing the fan motor, but that did nothing....
I own a 1988 Aerostar, short version, it's the 3.0L Automatic. It has 76,046 miles on it. Mechanically it has been great, always started through many storms here in Montreal, Canada. It still pulls very hard and I don't have a light foot. I change the oil every 2500 miles and change appropriate fluids accordingly. The sliding door is harder to close now and the rear door lock is broken other than that it's fine. I've repainted her 3 years ago, so she looks and runs great except for my above problem. Any ideas/suggestion would be most appreciated.
Old Nov 11, 2002 | 07:19 AM
chris eck's Avatar
chris eck
The vaccum modulator controler for the vent /defrost flapper door is not moving back and forth therfore its stuck in one position.The hose going to the modulator may be torn some where not allowing enough vaccum to operate the modulator,or the door itself may be jamed in place.My 93 with a/c has several duct doors under the dash.Took quite awhile to remove the top of my dash when i was trouble shooting a simular problem.
Old Nov 11, 2002 | 12:26 PM
Racerguy's Avatar
Racerguy
jtexfisher
21
Jan 26, 2014 04:38 PM
Big-Red-Lariat
2004 - 2008 F150
Oct 19, 2009 09:28 PM
james734
Apr 28, 2008 01:53 PM
dynamitedan
21
Aug 18, 2007 09:45 AM
John7894
Sep 9, 2003 10:08 PM
