reverse lights
Old Aug 28, 2004 | 03:56 PM
zmanz1's Avatar
zmanz1
reverse lights
i have a 1998 diesel extended van , and the reverse light fuse keeps blowing out.anyone know a fix for this problem?its an e350 thanks
Old Aug 28, 2004 | 05:42 PM
Franklin2's Avatar
Franklin2
Look for damaged wiring in the rear. If it blows right away, I would find a plug in the back harness and unplug it, and then see if the fuse blows. This might narrow the bad wiring down a little bit.
The back-up switch is usually located on the side of the tranny, so look for any wiring under there that may be laying against the exhaust, or rubbed through where it comes up the back of the engine and through the firewall.
Old Aug 28, 2004 | 07:36 PM
zmanz1's Avatar
zmanz1
thanks dave ill check thay out.
