Yesterday I drove my 92 f150, 5L, for about 30 miles, turning it on and off twice. The third time I started it, as I left the parking lot I was in I noticed a great hesitation, as if the engine was going to stall. I put it in neutral & it idled okay. It starts good & has power for lights & etc, but the amp & fuel gauges are now not working, although the amp gauge does a slight jump very briefly as I turn the ignition on. The engine idles fine, but as I start to accelerate, it hesitates and bogs down as if it was going to stall (it doesn't stall, though). If I continue accelerating (to about 25mph), it does not bog down as badly, but it still runs very roughly. I had my alternator tested & it's okay. I will welcome any ideas anyone has whick will possibly lend insight into my problem. Thank you
Did you ckeck the aletnater for cargeing just 13.8 or is it up to full capacity I also would check the ground wires my truck through fits like that and I ran a ground wire from motor to frame ,batt. to moter to batt to frame 12v elec dc acutlly run from neg to pos so ground is very imporant
See of you can get the codes from it, and post the codes here, so we can help you...get a code reader from walmart...it would be a good investment...in fixing your truck....
