About 3 weeks ago I ordered a 2005 FX4 150 SCab TrueBlue, Gray cloth captains chairs, floor shifter, 3.73 axle, moonroof, power sliding rear window, 35.7 gas tank (ouch), LT 18 inch tires, bright tubular running boards, and audiophile.
I did not order the reverse sensing option.
I do not have a build date yet.
2 questions:
1) Can I add the reverse sensing system with out delaying my order.
2) should I have a build date yet?
Hi Eastsideguy.
Welcome to FTE.
You need to contact your dealer salesman right away as he is the person that can change things on the order.If it is not to late.Do it now.
A suggestion is if you can do that, also add the tow package. It's a great addition even if you don't tow. Bigger radiator, altenator, battery, and heater cooler. Makes your truck all that more solid for a very small price addition. I love it.
