Replacement KeyLess Entry
Old Aug 27, 2004 | 01:51 PM
oggjay's Avatar
oggjay
Does anyone know how to program our keyless entry key fobs to work with our trucks..??? THanks Jay
Old Aug 27, 2004 | 10:18 PM
01stroker's Avatar
01stroker
oggjay, do you have your owners manual? The directions are in it. If you don't have it, let me know and I will get mine out tommorrow and get the directions to you.
Steve
Old Aug 27, 2004 | 10:34 PM
Kwikkordead's Avatar
Kwikkordead
Yeah, something about turning the ignition key on and off 10 times rapidly, I remember reading something like that.
Old Aug 28, 2004 | 05:54 AM
f350xlt460's Avatar
f350xlt460
get in the truck turn ignigtion key on and off at least 5 times (run-off-run-off...). Once the doors lock and unlock by them selfs, (leave the key in that position (probably run) press any button on the keyless entry fob. If you have more then 1 fob, you have to do them all within something like 10 seconds of starting to program
Good luck.
Old Aug 28, 2004 | 07:10 AM
01stroker's Avatar
01stroker
oggjay,In case you don't have your manual, here are the instructions (these are for my 2001, i would assume it would be the same for others):
Have all the transmitters available before starting.
You have 5 positions on the switch. 1 is accessory, 2 is the lock position (where you put the key in and out), 3 is the off position, 4 is the on position, and 5 is the start position.
  • Turn the switch from 2 (lock), to 3 (off) and cycle between 3 and 4 eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4 (on) position. The doors will lock/unlock to confirm that programming mode has been entered.
  • Within 20 seconds, program a remote transmitter by pressing any button on the transmitter. The doors will lock/unlock to confirm that the trans. has been programed. If the 20 seconds passes without pressing a button you will have to start over.
  • Repeat last step for each remote transmitter.
  • Turn the key to 3 (off) or wait 20 seconds. The doors will lock/unlock to confirm programming is complete.
I didn't get permission from F*rd to give this information out! Maybe I won't get hauled off!
Steve
Old Sep 1, 2004 | 11:01 PM
ultimatekimberly's Avatar
ultimatekimberly
this info helped me ... thanks!
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
tjtapley
Dec 10, 2005 06:32 AM
Aug 25, 2002 10:40 PM
cyprisfx
Oct 6, 2001 11:58 AM
Motorcraftsman
Jul 19, 2000 04:00 PM
