High Idle at Startup
Old Aug 28, 2004 | 10:26 AM
byronbgs's Avatar
byronbgs
Mine does the same thing. It's more pronounced since I changed the fan clutch. But it's at 1500~ RPM right after I start the truck then goes to 1K~ then to 600-700 RPM.
I installed a Sun Pro tach earlier this year from Pep Boy's $30.
I have noticed that if I give a tap on the gas that it will knock the idle down quicker.
Originally Posted by polarbear
Yep- my '93 5.0 does the same thing (always has, come to think of it). I like to wait for the idle to settle down before I shift it into gear, though. I imagine I'm saving the tranny a little grief. Laugh if you want, I'm still running the original 4EOD @ 190K miles.
I shift into Drive first to get the juices flow in the tranny then to Reverse. I have been having a loud clunk or clang sometimes when I would shift into reverse at a faster idle.
Old Aug 28, 2004 | 12:47 PM
93candycane's Avatar
93candycane
The tap on the gas will idle it down right away but that is also when it seems to drive sluggish. So long as I let it idle down on its own it will drive great for me.
Old Aug 28, 2004 | 01:11 PM
yardbird's Avatar
yardbird
I took care of the 1500 rpm cold idle on my 87 4.9. Not everyone will approve, but it works for me. I disconnected the electrical connection to my IAC, and adjusted the set screw on the throttle plate to where it idles at about 950 rpm. It will still go up to about 1100 when cold, but much better I think than reving to 1500 when it is 15 deg. outside and the oil is thick and not flowing good.
It has been that way for 12 years now.
Old Aug 28, 2004 | 05:34 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
There are instructions in the manual telling you to do this. You need no approval.
If I have an idle problem I usually look for vacuum leaks. Most old trucks have a vacuum leak or two, it never hurts to track down a couple.
Listen to other trucks start-up and see if they sound like yours.
Old Aug 28, 2004 | 11:46 PM
polarbear's Avatar
polarbear
loud clunk or clang
Makes sense- but check the bolts on the transmission crossmember- could be the source of that noise.
Old Aug 29, 2004 | 12:24 AM
couleeman's Avatar
couleeman
Check the ect sensor. If you want more of a reason why, ask tommorow when I sober
Old Aug 29, 2004 | 03:53 PM
byronbgs's Avatar
byronbgs
Thanks polarbear i'll check the bolts
Old Aug 29, 2004 | 06:10 PM
custom88's Avatar
custom88
The throttle plate stop adjusting screw on my 88" 4.9L EFI I-6 was set so as to allow too much air to bypass the IAC valve resulting in a high idle and this was accentuated during the ECM's warm up cycle. I simple set the throttle stop at 1/4 turn of the set screw.
