Yellow wires???
Old Aug 26, 2004 | 10:03 PM
justin04's Avatar
justin04
Exclamation Yellow wires???
Hey guys as you now i had to wire up a new ignition ( on my 1979 F100) cause the old one was cut out. Well i got it to start right up regular without jimmy rigging anything. But my battery dies overnight. I think i have a short or something. Well i was wondering if anyone knows what the two yellow thick wires are on the ignition plug i think those might be the problem? Thanks if you can help?
Old Aug 26, 2004 | 10:06 PM
Franklin2's Avatar
Franklin2
They are the main 12 volt feed from the battery positive. Do this to check where your drain is.
Old Aug 26, 2004 | 10:08 PM
justin04's Avatar
justin04
Thanks can you explain a little more. Sry. Thanks. Does it matter with one i soder them to? each one has its own sepreate spot?
Old Aug 27, 2004 | 12:50 PM
Franklin2's Avatar
Franklin2
I don't think it matters which one they go to. I am looking at a 1980 diagram, and the two yellow wires go to a common splice in the harness where they are soldered to one yellow that goes out to the fusible link at the starter relay.
Hook up a test light just like the diagram above, with a good charged battery. If the light glows bright, you do have a drain.
The first thing to do is disconnect the alt output wire. If the light goes out, then your alt is the source of the problem.
If it still glows bright, then you can start pulling fuses. If one of the fuses makes the light go out, then that's your drain, and you can investigate from there.
Old Aug 28, 2004 | 10:08 PM
justin04's Avatar
justin04
tHANKS... ILL GET BACK TO YOU SOON.
Old Feb 25, 2005 | 04:25 PM
justin04's Avatar
justin04
i resently changed the wiring harness in the dash and disconected the alt. and the light was still on is there any thing else that could be shorting out? thanks
Old Feb 25, 2005 | 09:31 PM
Franklin2's Avatar
Franklin2
Did you pull each fuse out one at a time while you watched the testlight?
Old Feb 25, 2005 | 09:37 PM
justin04's Avatar
justin04
no i just had everything unpluged and there was still a short.
Marine5811
24
Apr 23, 2018 03:23 PM
D & D
Sep 18, 2014 08:14 PM
Hogtrapper
Mar 13, 2013 08:53 PM
pancake
Apr 11, 2003 11:26 PM
