Painting room?
Old Aug 26, 2004 | 09:00 PM
killerklown's Avatar
killerklown
Painting room?
Anyone ever prime and paint over wall paper, or will it just peel?
thanks
Old Aug 26, 2004 | 09:22 PM
theologian's Avatar
theologian
I have lived in a house where it was done, and it did not peel, however the only time I tried to do it, it peeled.
Theo
Old Aug 26, 2004 | 09:24 PM
Howdy's Avatar
Howdy
I have, but it looks like you painted over wallpaper. Sometimes you can just peel it off. Most of the time it won't and renting a steamer and a few tools is the easy way. Once you get it off, if it's been textured, a light sanding will knock down the old glue. Then you can go ahead and paint. I'm pretty good at hanging wallpaper. I'll never do it in my own house again, because I hate removing it when the pattern goes out of style, (like the 6" bright orange and yellew daisies that used to adorn one room here - since the 70').
Old Aug 26, 2004 | 09:36 PM
RoyalFord's Avatar
RoyalFord
My dad is a professional painter, he said it shouldn't peal
Bryan
Old Aug 27, 2004 | 07:36 AM
jroehl's Avatar
jroehl
Wallpaper does not always come off easy. We gave up using steamers many years ago because they often will damage the drywall paper underneath. A scoring tool, hot water (maybe with some DIF mixed in) and a scraper is the best way to go. But, if you must paint over it, the way to do it is to paint the paper with an oil primer such as Kilz (or shellac, like BIN), then skim-coat the seams with drywall joint compound so that they don't show. Then top-coat with whatever paint you want.
Jason (pro painter)
Old Aug 27, 2004 | 08:51 AM
ChiefsFan's Avatar
ChiefsFan
Just get some wallpaper remover like DIF and spray it on there. If it is the paper type it will soak right in and with a little elbow grease comes right off. If it is vinyl type of paper you will need a scoring tool. Just score it, spray it, scrap it. After either scenario you will need to prep the wall a little. I have removed numerous wallpapered rooms and painted. So its not to hard just time consuming.
jake00
19
Feb 21, 2008 08:30 AM
omni
Feb 5, 2007 12:23 AM
ivanribic
19
Sep 27, 2006 11:44 PM
bumpzter
13
Aug 6, 2005 04:11 AM
bosshoss
15
Nov 13, 2003 03:15 AM
