Injection Lines
Old Aug 26, 2004 | 04:54 PM
rbdutton's Avatar
rbdutton
Injection Lines
Anyone able to tell me the location of fuel injection lines on the back of the injection pump?
Old Aug 26, 2004 | 06:48 PM
captjohn's Avatar
captjohn
Looking at the pump where the lines go starting at 1 o-clock and going clockwise:5 4 3 7 2 1 8 6. Install lines i following sequence 2 7 1 3 8 4 6 5 this is from Haynes Techbook Diesel engine repair #10330 at AZONE about 15 bucks. Now maybe you can help me out? What is the best way to bleed HP lines after doing head gaskets? thanks
Old Aug 26, 2004 | 06:56 PM
captjohn's Avatar
captjohn
PS this is for non-DI turbo
Old Aug 27, 2004 | 12:12 AM
Spectramac's Avatar
Spectramac
Have all the lines cracked loose at the injectors. Then after a good battery charging, crank the engine over with the pedal on the floor for 10 seconds. Wait 30 seconds to a minute and try it again. Keep it up till the lines get wet and bubbley or the batteries slow down (whichever comes first). Tighten the lines down and fog 'er up. You may have to stay on the throttle some until it smooths out.
Old Aug 27, 2004 | 06:40 PM
captjohn's Avatar
captjohn
Thanks for the help. Was easier than i thought it would be.
