towing with 4.6
Old Aug 26, 2004 | 09:40 AM
flam'in f150's Avatar
flam'in f150
towing with 4.6
I have a f150 2002 4 door with 4.6 and 3.55 rear and aux cooler. I also have the heavy duty battery and heavy shocks. My question is, has anyone pulled a TT with this style truck and how was the ride. I'm planning on buying TT around
5500# gvw. I need imput. Cann't get rid of my truck she's my baby with a flam'in paint job. Wasn't planning on buying a TT.
Old Aug 27, 2004 | 10:14 AM
jtmerritt's Avatar
jtmerritt
Towing With A 4.6
Contact Ford to get the tow ratings for that truck. Also, Trailer Life publishes tow ratings and had a book listing tow ratings for most vehicles. You need the ratings before you can decide on what weight trailer you can pull safely with that truck.
John
Old Aug 27, 2004 | 05:13 PM
trike1946's Avatar
trike1946
I have a 99 Expedition with a 4.6 and 355 diff. The book says a little over 5000#. The front face of the trailer can change that. The bigger it is the more wind resistance. Check with Ford. 5500# will be pushing it, and the suspension. Good luck.
Old Aug 27, 2004 | 05:39 PM
rclarke's Avatar
rclarke
The Ford towing guide for 2002 shows:
2002 F150 Supercrew (4 door?) with 4.6, 3.55 GCVW 11,500lbs Max tow 4x2=6600lbs 4x4=6200lbs. Because of the extremely short bed Supercrews are not recommended for 5th wheel towing.
If by 4 door you meant Super cab the towing max is 300lbs more. GVWR is the same.
I think you would be happier towing if you stay well below the maximums.
