Bronco II Ford Bronco II
Increading idle???
Old Aug 26, 2004 | 02:00 AM
Aggie05's Avatar
Aggie05
Increading idle???
89 BII 2.9 4x4, sometimes when im driving i can let out on the clutch and the vehicle keeps going it idles around 2400 or so. AFter aplly ing the breaks and slowing down below like 15mph the idle will return to normal, I am not getting a check engine light. What are some of the common reasons for this?? ANY IDEA?
Old Aug 26, 2004 | 09:41 AM
mrshorty's Avatar
mrshorty
I'd start by checking for a vacuum leak. From your description, it could be an intermittent fault, which can make it hard to find.
And, just because the check engine light doesn't come, doesn't mean the computer can't find and report faults. I'd run the self-tests anyway.
