73 Wipers????
Old Aug 25, 2004 | 10:48 PM
toyotaguy's Avatar
toyotaguy
73 Wipers????
my wiper switch dosen work. I have tried three switches, and curently have a new one. I can use a jumper wire between the leads and make the wipers work. so i know the motor works and i have power. any leads?
thanks
justin
Old Aug 26, 2004 | 08:27 AM
73Custom's Avatar
73Custom
Do you have 2 terminals with power? If I remember correctly, there is a power wire for the washers (in the two wire portion of the connection) and power wire for the wipers in the larger portion of the plug. Do you find two power wires?
Marty
Old Aug 26, 2004 | 07:17 PM
toyotaguy's Avatar
toyotaguy
maby?
I think i might only have one power wire, if i rember right i had to use both plugs to make the wipers work. I will check that.
thanks
justin
