I have a 1970 F250 with a 390. The battery won't stay charged up. I had the voltage regulator, alternator, and battery all tested and they are all good. I have replaced them all anyway recently. If I charge it with a battery charger it will hold a charge, but as soon as I drive around for about a week it is dead again. The battery is not being drained from just sitting there. I let the truck sit for about 2 weeks and the battery was still good. I think the alternater is not charging it. How can I test to see if the alternator and regulator are working, while on the truck? Thanks
while on the truck is easy, start the truck and unhook the battery, if the truck stays running the alternator is working, if it dont, well you got your answer. then take it off and take it to autozone, they will test it for free.
I have had it tested at Autozone. They said it was good. Besides, in the service manual it says not to take the battery cable loose while it is running because this will damage the regulator.
Since all items tested good, you probably have a wiring fault at a connector. Most likely, the pin inside the connector on the voltage regulator is being pushed out of the connector. Or, the alt. is not receiving ign. on voltage.
i never read that in my maunal, wait i dont have a manual, lol
well i have a 70 f250 and i have unhooded the battery many a times.
quickest and easiest test to confirm alternator working, cause if it anit, the engine gets no power for spark, it dies almost in one breath.
As an alternative to FordLover's remove-the-cable technique, you can check it with a voltmeter. When the engine isn't running the battery should show about 12 volts. Check it again when it's running; it should be around 14 vots. If it's still 12, I'd look at the alternator no matter what AutoZone said. Good luck.
jor
I think there is a fusable link between the alternator and starter solenoid. Check it and see if it is broken. Many times when they blow the insulation in the wire is intact, but the wire will be burned open.
In addition to what JOR said, I would actually rev the engine higher, say 2000 rpm to see if the voltage picks up. At idle, you usually won't see the volts jump up.
At idle the alternator may not be spinning fast enough to charge the battery. Had terrible problems with my 69, when it was still Dad's, and he just putted around town at 25. It wouldn't keep a charge either.
An old boy up at the machine shop, had a larger pulley that fit, and solved the problem. I'm not sure what it was off of, or if he made it up himself.
get a voltmeter and see what the battery voltage is at a fast idle. If it is 12.6 or lower, put the voltmeter on the Field terminal of the alternator. If you have around 11 volts, the alternator is bad. If there is no voltage, the regulator or the wiring has a problem.
well, i just bought it last month so i know that's not the problem...
working at autozone, i know for sure that just because a part is new, doesn't mean it works. however, it is rare that things are broken out of the box. personally i'd begin with checking for a burnt link, then make sure that all wiring is tight, clean, intact, not shorted, etc. if all that seems good, take all three parts (regulator, alternator, and battery) to autozone... we can test all three of them individually rather than testing the system as a whole while it's on the truck. it may also be advantageous to install a volt guage. the stock C/D guages are before my time so i don't know how reliable they are, but i do know that keeping a close eye on my voltage has been a big help for me in the past.
