Help with windows please
Old Aug 25, 2004 | 08:45 PM
FCantu's Avatar
FCantu
Question Help with windows please
I have a 1986 ford f 150 van with power windows and locks. They stopped working and I can't seem to find where the fuse is for these. Can anyone help????
Thanks
Frank
Old Aug 25, 2004 | 11:31 PM
locknkey's Avatar
locknkey
You have a fuse box under the column area? It should be label power/window. Were they ever working?
Old Aug 26, 2004 | 06:50 PM
FCantu's Avatar
FCantu
Being that its a conversion van it was not even built in the fuse box. They were added. Yes they were working. Thanks
Old Aug 26, 2004 | 08:03 PM
locknkey's Avatar
locknkey
Then if it was added, mebie they have an inline fuse someplace under the dash area, trace your wires coming out of the door frame an examine the under wiring from where the wiring harness is, if it goes all the way to the fuse box, it may be wired in direct, making the switch controls a suspect in loose wiring connection or a burned wire melted in two pieces. Disconnect the controls on the drivers door, an examine the switch an other window/lock controls.
