Sponsored by: Real Truck
srs air bag problem
Old Aug 25, 2004 | 07:34 PM
scott4682's Avatar
scott4682
Question srs air bag problem
Hello fellow ford owners. I have been following this forum and going through the archives. I have found a lot of great info given by members and am looking forward to contributing.I have a 1999 f250 super duty that i recently had a fisher plow frame installed on . soon after the airbag light started blinking a code 25. I had a scaner run on it and it came up with a code B18-71- passenger airbag disabler modual fault. Does anybody know where the modual is? Do you think this fault could be caused by the plow frame instalation?
Old Aug 25, 2004 | 07:47 PM
n578md's Avatar
n578md
Same problem with mine after I play with the passenger airbag de-activation switch. To get rid of it, I put the key in the switch and rapidly switch back and forth (on and off) a dozen times or so. I think they have too much grease on the contacts and playing with it a while will make better contact. Maybe they cut or unplugged some wires going to or from the switch while installing the plow controls too.
