2005 5 Speed?
Old Aug 25, 2004 | 07:06 PM
T100's Avatar
T100
Question 2005 5 Speed?
Does anyone here know if FORD has decided to produce a 2005 F150 with a MANUAL TRANSMISION?
Old Aug 25, 2004 | 07:51 PM
fatman66's Avatar
fatman66
You will be able to get the 5 speeds manual only with the 4.2L V6, not available with 4WD. Both the V8's still get the 4 speed auto in 05.
Old Aug 25, 2004 | 07:54 PM
DonsFx4's Avatar
DonsFx4
Only with the new 4.2L V6 do you get a 5-speed manual.
Plus you get a set of defibullators for the engine trying to pull a 6,000 lb truck.
If they come out with a decent one to mate w/ the 5.4L, I'm in there!
(But don't let my new truck hear that!)
Old Aug 25, 2004 | 08:26 PM
asinatra's Avatar
asinatra
hello? its called gear ratios...
and since you cant get it in a 4wd that knocks off at least 200lbs of drive line. and not everyones truck weighs 6k, mines 4600lbs.
Old Aug 25, 2004 | 10:04 PM
T100's Avatar
T100
Unhappy
Are you sure that the 2005 with a 5spd. will NOT be available with 4WD?
Old Aug 26, 2004 | 07:42 AM
fatman66's Avatar
fatman66
99% sure, there were no specs available for the 4.2L V6 05 F-150 in the 4WD column and I read in a press release somewhere that the 5 speed manula will only go behind the 4.2L V6 and the 4.2L V6 will only be available in 2WD. Sorry to be the bearer of bad news but trust me you are not the first one here to wonder why not.
Old Aug 26, 2004 | 07:55 AM
Truckasaurus's Avatar
Truckasaurus
Sure would be nice if they offered the option. Even if it was a special order from the factory it would be pretty cool to have the 5.4 4x4 with a manual. I suspect it would be limited to XLT trims but even still it would be nice. Years ago they were still producing a fair amount of trucks this way and I would have to believe that there are still people who like the control of a manual.
I have my Cobra to give me my manual tranny fix, but without it I would be itchy to be rowing the gears in my truck.
T
