1st time 150 Owner Question re/ speed control
Howdy everyone! I am brand new to the group, bought my first F150 two weeks ago, a 2004 Super Crew Lariat. What a wonderful driving experience! I was astounded at how comfrotable and quiet the ride is. (Now my only concern is that my wife wants to take it)
One quick question. I have noticed that the speed control seems to work on flats surfaces and hills, but that it has very little control over a downhill. It is not untypical, if I have the unit set at 55, and hit a decline for the truck to hit speeds of 70-80mph unless I ride the brakes. I drove an SUV for years before this truck and although it would gain some speed on a downhill, this seems to be an issue where the gas is not being released.
I know the truck is a lot heavier than anything I have owned in the past, and I will ask the dealer when it goes in for its first service, but I was wondering if you can give me an idea of what kind of speed variations would be normal?
Thanks in advance from the group newbie!
Bob
Bob
BobJar:
I would have the dealer check it out. Not normal. I also have a Lariat Supercrew and the speed is constant when set in cruise control. I have seen a post where another F150 owner is having the same increase in speed as you are having. Do a search on the topic and hopefully you can get additional information. Should be an easy fix. What color do you have?
Originally Posted by dgordon
BobJar:
I bought a solid White 4x4 with a tan leather interior. Added Husky mats and a Roll top cover so far...... :-)
Bob
I take mine out of Overdrive on downhill grades. If it still continues to speed up then I drop it into 2nd. I haven't had any problems doing this and it holds my speed. The owners manual says that the transmission won't shift into a lower gear until the speed is safe to do so, so you may need to slow down to about 60 before shifting into 2nd. BTW the owners manual recommends engine braking to maintain control and prevent riding the brakes. I know there a lots of people who will disagree and say that changing brakes/rotors is much cheaper than engines/transmissions. I have yet to have any problems with any of my vehicles engines/transmissions related to engine braking.
Originally Posted by ATCS2004
I take mine out of Overdrive on downhill grades. If it still continues to speed up then I drop it into 2nd. I have yet to have any problems with any of my vehicles engines/transmissions related to engine braking.
