Rough idling 03 model 7.3
Old Aug 24, 2004 | 11:18 PM
fordpower2003's Avatar
fordpower2003
Red face Rough idling 03 model 7.3
I have an 03 model stroke and it idles pretty rough, and the only thing i can think of is the programmer. or the aftermarket oil crossover hose.
Any suggestions will be appreciated
Thanks in advance,
Fordpower
p.s. I finally got to race the new bodystyle high output cummings the other day, it was chipped out and had exhaust, but to make a long story short "i'd rather be stroked than rammed" he got stroked!!!!!
Old Aug 24, 2004 | 11:24 PM
Pikachu's Avatar
Pikachu
Well, you can rule out the programmer by resetting it to stock and seeing if it clears up. The oil crossover should only improve the idle. Elsewise, under-valve-cover wiring harness comes to mind.
Old Aug 24, 2004 | 11:25 PM
Kwikkordead's Avatar
Kwikkordead
The oil crossover hose will actually smooth out the idle, so I doubt it's that. You have a 10k or clamp mod on that thing?
Old Aug 25, 2004 | 03:56 AM
slc10844's Avatar
slc10844
Have you tried a fuel additive like Stanadye Performance and a fuel filter change? You may have gotten a bad batch of fuel.
Old Aug 25, 2004 | 05:38 AM
Technitom's Avatar
Technitom
Veteran: Navy
you may have introduced air into your fuel system with the crossover mod. it can idle rough for a couple of days until it works all the air out... I read that here in one of the threads ...
Originally Posted by mueckster
Was the plug you replaced on the end of the cylinder head? You could have gotten some air in the injector oil feed system when the plug was removed. It may take a little time for it to purge out of the injectors while running. I recently installed a high pressure oil cross-over line and took a couple of days to get rid of the air before I noticed a difference.
Old Aug 25, 2004 | 06:27 AM
jschira's Avatar
jschira
How old is your oil?
Might be due for a change or switching brands. The 7.3s are very tempermental when it comes to oil. My old '99 and my '03 both seem to like anything that I give/gave them. But many seems to dislike one oil or another.
