Tank selector valve
Old Aug 24, 2004 | 04:03 PM
bonechief's Avatar
bonechief
Angry Tank selector valve
I have an 84 Ford F250 with 460. Front and rear tanks have electric fuel pumps.....The selector valve i think is causing a flooding problem......But i cant find one with the right conection plug on it everyone here has a flat 6 round pin plug....I need a flat 5 flat pin plug......any one with any suggestions......................
Old Aug 24, 2004 | 04:12 PM
lmadore's Avatar
lmadore
The selector valve would not cause flooding, unless you mean that it is transferring fuel between the two tanks causing the full tank to fill even more.
You might want to clarify what is flooding.
Old Aug 24, 2004 | 04:35 PM
bonechief's Avatar
bonechief
When you use the rear tank the carb floods. the vavle isnt letting the return gas from the carb go back into the rear tank.
