Cleaning Carpets
Old Aug 24, 2004 | 10:08 AM
dvsmnstr's Avatar
dvsmnstr
Cleaning Carpets
hey guys, I have to clean the carpets in my expy tonight I was wondering what the best way to shampoo/clean the carpet is? and what product works best? thanks for any info
john
Old Aug 24, 2004 | 01:47 PM
Reynolds's Avatar
Reynolds
I have steam cleaned and washed a lot of my carpets and it doesn't really make a difference. If there is odor, you want to get something to kill that but if just dirt, a good steam and vacuum using any off the shelf should do fine.
Old Aug 24, 2004 | 02:15 PM
tonum24's Avatar
tonum24
If you have any really bad spots then spray a little simple green on them-rub with hot water/brush if necessary. I steam clean mine once a year.
Old Aug 24, 2004 | 02:18 PM
dvsmnstr's Avatar
dvsmnstr
don't want to buy a steam cleaner.. you guys ever try a brush/wash cloth and some carpet cleaner and warm water?? i'll ask some of my friends to see if they have one of the steam cleaners.. mostly salt water stains on the drivers side floor by the door panel from loading up my jetski.
Old Sep 18, 2004 | 02:59 PM
78Explorer's Avatar
78Explorer
Without a doubt, the BEST cleaner (for spots/stains anyway) is Spot-Shot - blue/orange spray can - Lowes has it for about $4/can - it is VERY good stuff for grease/oil/rust/just about any stain you might encounter!
Scott
Old Sep 18, 2004 | 05:30 PM
Aztrainer's Avatar
Aztrainer
Scott
Yes it is great, but remember that you will not be driving for a while when using it due to odor. (It is VERY powerful in an enclosed enviorment)
I do it at night and leave the windows down in the garage. Dry and clean in the morning.
The way that I have had success with Spot-Shot is to use a damp cloth and a dry cloth approach. Spray the area and let is soak in for about two or three minutes and then take your damp cloth and rum the area. Once you feel that it is completely cleaned, take the dry cloth and clean the area. Keep switching cloths as they get dirty and they WILL get dirty. In about thirty to forty minutes it will be clean and you will have had a good workout. Hope this helps.
Old Sep 18, 2004 | 06:04 PM
tonum24's Avatar
tonum24
Very bad spots like oil-then simply rub in some "mechanic" hand cleaner like gojo. Simple green is very good and smells ok-I just take the entire mat out of my car and completely soak it with water and scrub away-use a shop vac to suck it dry and leave in sun or in house overnight.
Old Sep 20, 2004 | 02:36 AM
pounder90's Avatar
pounder90
Blue Coral Carpet cleaner. Just let it foam for a while, then scrub with a carpet brush. Doesn't smell too toxic and you'll be amazed at the stains that will come out.
Old Sep 20, 2004 | 04:12 AM
78Explorer's Avatar
78Explorer
I've been using Blue Coral's carwash soap for years and have been happy with it. Anyone know of a reason not to use it?
Thanks,
Scott
Old Sep 21, 2004 | 12:39 AM
pablocruz69's Avatar
pablocruz69
I have three children 7, 4, and a 1 year old, you talk about stains!!! When I take my expy to the car wash I use the sprayer at the wash to clean my floor mats and that has worked for me for three years, I first spray blue coral on then hose them down and sun dry. I have also had to take out the seats and the carpet and I used the power washer along with the blue coral, I hung the entire carpet over the swing set let it dry over night and the carpet stains were gone odor was gone and it looked almost brand new! Its a lot of work but it has to be done. New carpet will run anywhere from 250 to 350 dollars if you want to go that route, but the car wash is my best friend. Good luck
Old Sep 21, 2004 | 07:26 AM
hceptj's Avatar
hceptj
I use the same stuff...for years...
