Belt squeal on cold start. 5.4L
Anybody have this problem? When I first start the engine in the morning, it sounds almost like a belt squeal. It's not continuous. The noise appears each time the belt comes around.
It does change with engine speed and it is still there even if I turn the A/C off. Doesn't go away until the engine warms up (about 5-10 minutes). Never happens on a hot start. Turning on a bunch of lights and electrical load does not change the sound either. Happens in park, neutral, drive, and reverse.
Last weekend, I tried belt dressing right after I started the engine. Only seemed to help for one day.
Thanks for the help - - just want to make sure it's not more serious.
5.4L 4x4 screw
3.73LS
Moonroof, audiophile, capt. chairs, power slider, bed extender, factory chrome nerf bars.
FREE factory installed options: Shimmy at 50-55, Shudder on turning takeoff, throttle lag, rebounce of rough roads. Living with 'em, cause I still love my new truck at 1400 miles.
5.4L 4x4 screw
3.73LS
In my experience, once you put belt dressing on a belt/pulley, it will squeal until the dressing wears off. If the belt is in good condition, no drive accessories are frozen/damaged (alternator, water pump, power steering pump, etc), and the tensioner is working correctly, the belt should not slip or squeal. On occasion, however, dirt and/or water will get on the belt or pulley and cause a squeal. From my experience, belt dressing does more harm than good.
not anymore
Mine did it for a while. I did notice it more when the humidity was higher and on cooler mornings. I thought maybe some grease or oil had splashed on the belt somehow, so I took a hosepipe and sprayed the belt while the engine was running. I also sprayed the A/C clutch as well because that's where the problem seemed to eminate from. I noticed about two weeks ago that it doesn't do it anymore. I guess that fixed it.
5.4L 4x4 screw
3.73LS
5.4L 4x4 screw
3.73LS
another glitch?
Foadtuff, if this is true, wouldn't that lead to premature wear on the belt, if not the other components? I noticed mine did it this morning, but stopped by the time I got to the end my road. You know how the service depts. are. If they don't hear it or see it when it's happening, it's considered "normal". Well, I travel interstate about twenty miles and if this thing pukes on the road, I'll definitely "not be normal" when I get to the stealership! I sure as H*** hope these first year glitches don't get the best of me. It seems like everytime I hit these forums, some new glitch pops up. Lets take a count and see how many glitches we have now. Ok, I feel better. Thanks for letting me vent.
twangysmitty
24
02-20-2024 06:03 AM
jhaas63
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
09-07-2012 11:28 AM
