1978 - 1996 Big Bronco
Torx bit size
Old Aug 24, 2004 | 06:07 AM
scionti 94's Avatar
scionti 94
Torx bit size
The nylon bushing on my door latch became brittle and broke off. Picked up a couple of bushings at local auto parts store, but do not have the correct size torx bit to remove the door latch bolt. What size torx bit is needed Appreciate any information.
Old Aug 24, 2004 | 10:53 AM
body9599's Avatar
body9599
It's a torx - 50
Where did you get the bushings and how much were they?
Old Aug 24, 2004 | 04:55 PM
scionti 94's Avatar
scionti 94
I picked them up at Discount Auto Parts and they were under $5.00. There were four, two long and two short. Two of them fit the tailgate latch and the other two fit driver and passenger door. Thanks for the heads-up on the T-50.
Old Aug 24, 2004 | 06:35 PM
scionti 94's Avatar
scionti 94
Body9599:
I forgot to mention the brand name is "HELP" and the part # is 38424. It is called a striker bolt bushing kit. This particular brand carries a lot of those little hard to find parts.
Old Aug 24, 2004 | 08:01 PM
body9599's Avatar
body9599
Awsome...thanks for the info!
Old Aug 28, 2004 | 11:09 AM
body9599's Avatar
body9599
Just replaced mine today with the same part number. All i can say is wow. I never even knew that the tailgate was supposed to have bushings...i just knew it rattled like crazy and never seemed to close right. Now it's as sung as can be...same with the doors. Good stuff
Old Aug 28, 2004 | 01:00 PM
scionti 94's Avatar
scionti 94
Glad to have been able to help and pleased that it all worked out for you.
fred_79f250
Oct 29, 2022 10:40 AM
Matt1966
Feb 19, 2017 04:22 AM
Treacy
Jul 6, 2016 04:47 PM
jbourne84
Feb 9, 2016 07:57 AM
