Engine swap
Old Aug 23, 2004 | 04:14 PM
cushing's Avatar
cushing
Engine swap
I have a 76 150 with the 400 automatic 4x4, I want to put in a fresh 390 and C6 that came out of a 75 250 2wd. I have the mounts. Is it a do able swap? I do know the 390 will not mate to the 400 tranny. Thanks for the help. Jim/Cushing, WI
Old Aug 23, 2004 | 04:59 PM
poorfolks's Avatar
poorfolks
To use the 2wd c-6 you will need to use the tailshaft out of the 4wd c-6 for the proper length and splines.
Old Aug 23, 2004 | 05:30 PM
cushing's Avatar
cushing
I am not familier with any of this stuff anymore, is the tranny on the 400 a C6? The reason I ask is that we tried to install a 360 into the truck and the bell housing was wrong. Thanks, Jim/Cushing, WI
Old Aug 23, 2004 | 06:12 PM
fellro86's Avatar
fellro86
both trannys are C-6's, just different bells. The tailshaft length won't let you use the 2wd on the 4wd setup, without tearing the trans totally down to replace the tailshaft, or get a trans for the 390 4wd.
Old Aug 23, 2004 | 06:21 PM
cushing's Avatar
cushing
Ok well now I need to find a C6 that was set-up for 4wd. maybe this is getting to be to much.
Thanks, JimG/Cushing, WI
