what gauge should the map sensor vaccum line be??? does it matter if its the same size as OEM??? i ask becasue a rat ate alot of my line underhood , so i patched it with a smaller line , but now it has a delay in my foot going down and the truck responding.
think it might be because of this?????the line i patched it with is the small line that goes to the heater controls and all that , it fit inside of the line going to the map , so i crammed it in there and glued it shut , but if it needs to be replaced with the bigger gauge , can do
