Help!!!!
Old Aug 23, 2004 | 08:18 AM
89 blk 250's Avatar
89 blk 250
Help!!!!
Hello fellow Enthusiasts,
I have a 89 f250 4x4 5.8 liter that won't run. It all started about a month ago with sudden stalling at operating speeds and hard restarts. Replaced the control module at the dist. ( DID NOT HELP ) . Then thought I had a fuel problem... pump, relay and inertia switch are good and replaced filter. Then noticed that the truck would rough idle and stall on an incline , but that soon passed to where I'am at today. Hard starting ,with no idel and the temp and oil pressure are pegged to the left of guage. also no check engine lights. Is this a possible ecm issue. thanks for any help.
PS
Again HELLO!... I am a new member and have enjoyed reading posts in the past.
Old Aug 24, 2004 | 07:50 AM
89 blk 250's Avatar
89 blk 250
check back to Help!!!! Thread
Hello,
I really didn't think this would stump all you Folks, I guess it did . I will pull codes if the computer is ok, when I discover the problem I will sure let you all know. Thanks
