2003 Expy rear susp. upgrade
Old Aug 23, 2004 | 07:40 AM
Sayonara's Avatar
Sayonara
I have an '03 Expy EB. I also have a 10000 boat that I would like to tow(total weight with trailer and gear). I know what most of you are going to say..... but the boat stays in the water 90% of the time. I would trailer it out to the lake in spring and pull it out in late fall. during the summer I may take it out once or twice for a trip.
With this being said, I am assuming the boat will "squat" the rear end quite a bit. Are there any suggestions for suspention mods. to decrease this "squat". With the Indep. Rear Susp. I am lost as to what to do.
Other mods I will do is a new trans pan with incresed fluid capacity and a temp sensor port. K&N air filter and better performance exhaust. Any suggestions here would be great as well.
Thanks for you expertise!
David
Old Aug 30, 2004 | 11:25 PM
03GrnEBExpy's Avatar
03GrnEBExpy
If you have the Load Leveling Suspension the truck should stay level. I had an 03 without it and the truck would squat with any significant load. I got the LLS on the 04 and it doesn't squat at all.
Old Aug 31, 2004 | 07:32 AM
jknoll's Avatar
jknoll
Try airliftcompany.com. They make air lifts to fit your inbetween your coils. Check out the web site and e-mail one of the sales reps. They are very friendly and may offer other advice if they can't help.
Old Aug 31, 2004 | 08:30 AM
Sayonara's Avatar
Sayonara
I do not have the LLS. (wish I did)
Do you know if I can go back to my dealer and have it installed?
If not I will look in to the aftermarket systems. THanks!
David
Old Aug 31, 2004 | 09:52 AM
ltolson's Avatar
ltolson
David
You might look into a weight distibuting hitch. They make them for boat trailers and would be more economical then a suspension upgrade. Try www.equalizerhitch.com. Also do a search at www.trailerboats.com forums for weight distibuting hitchs. Alot of info.
Larry
87wreckerman
Sep 24, 2022 11:22 PM
mwells
Dec 29, 2014 09:13 PM
fshngan
Apr 25, 2010 03:33 PM
bfin
Oct 1, 2004 06:28 PM
mic
Jan 8, 2002 12:52 AM
