Sponsored by: Innova
DVD remote?
Old Aug 22, 2004 | 11:26 PM
curlymoe's Avatar
curlymoe
DVD remote?
Just traded the 99 expy for a slightly used 03 expy (18000 miles). It does not have a remote control for the DvD player. Does anyone know where to get one (besides the stealerships). Thanks
Old Aug 23, 2004 | 01:34 AM
RomerB2's Avatar
RomerB2
idk if this would work, but have you tried a universal remote from walmart or somewhere like that? i figured you might be able to match up brands and get a match, i've never tried anything like that though
Old Aug 23, 2004 | 07:27 PM
curlymoe's Avatar
curlymoe
I have thought of that, but without a brand name it would just be a hit and miss.
Old Aug 23, 2004 | 11:55 PM
RomerB2's Avatar
RomerB2
so what kind of system is this? was it stock or what? usually if it's stock it has a brand, and those universal remotes have a search for codes button, it may be worth $8 to try
Old Aug 24, 2004 | 05:52 AM
prcrboy's Avatar
prcrboy
Delphi made the factory unit. Check ebay, I have seen several last few weeks. If that doesn't work, the dealer can order one.
Instead of buying one to try, go by a local shop that installs dvd, and ask them to try one of their remotes.
Old Aug 24, 2004 | 03:43 PM
RomerB2's Avatar
RomerB2
good idea, i want a DVD system in my BII but i think they're kinda expensive, do u know where i could get one for really cheap?
Old Aug 24, 2004 | 04:34 PM
prcrboy's Avatar
prcrboy
I got mine, a factory 2003 model, off ebay. With shipping it was about $225. My particular one was first gen. without wireless headphones, but with modulator works great!
Old Aug 24, 2004 | 06:59 PM
RomerB2's Avatar
RomerB2
is that for screen too? or how does that work? and where does it mount at for you? thanks
Old Aug 24, 2004 | 07:28 PM
curlymoe's Avatar
curlymoe
Thanks for the info, It is a stock unit. I will try your suggestions and let you know what I come up with.
Old Aug 24, 2004 | 08:01 PM
prcrboy's Avatar
prcrboy
romer,
The stock unit is a combo type, built in dvd player with screen. It will mount on the ceilling and can be adapted to fit ANY make or model car/truck. I posted on this forum before the 12 pin configuration and someone posted the 20 pin this week.
I have complete instructions if you need them somewhere. Basically you have to make a bracket to install the dvd onto the roof and then cut the headliner to allow the wiring. After that its just simple wiring. The factory dvd system has a real good picture quality and holds up to the vibration of road travel very well.
Old Aug 24, 2004 | 10:59 PM
RomerB2's Avatar
RomerB2
sounds like a good deal, i might have to get me one of those, lately ive done a lot of work on my B2 that has been relatively cheap, time to get into the ole bank acount and get a negative number when i check out my account online
Old Aug 30, 2004 | 06:55 AM
prcrboy's Avatar
prcrboy
Curley,
I discovered through someone else that oneforall remotes will work on our dvd systems. He was using model URC-4041. LOL.
Old Aug 30, 2004 | 08:54 PM
curlymoe's Avatar
curlymoe
Thanks Guys, I tried 2 universal remotes, 1 RCA brand and 1 Phillips brand, I could not get either one to work. I finally found one at a car radio web site. It looks like it came from the dealer, even has a ford part number. Any way problem is solved thanks to everyone for thier help.
Old Aug 30, 2004 | 11:22 PM
RomerB2's Avatar
RomerB2
your welcome, i thought the universal might work but looks like it didnt, dont loose this remote..
Old Sep 7, 2004 | 01:39 PM
EightSecV6's Avatar
EightSecV6
Originally Posted by prcrboy
romer,
The 20 pin unit works like a champ with the modulator too, I mounted mine in my crew cab by securing the 2 front mounting holes in the unit with machien screws,Loctite and oversize fender washers, on the rear 2 holes I predrilled the roof support rib and used 2 self tapping screws, it looks 100% factory and sounds great, it plays in stereo too! I posted the info here:
https://www.ford-trucks.com/forums/s...d.php?t=274171
