Aerostar Ford Aerostar
oil funnel modification
Old Aug 22, 2004 | 12:03 PM
psyche's Avatar
psyche
On a 3.0, has anybody modified/straightened the oil filler pipe so you can just pour in oil without a funnel? It's a shame to have it bent down when the diameter is large enough for an easy refill.
Old Aug 23, 2004 | 08:03 PM
roree's Avatar
roree
I found a funnel that has a bendable wide tube that works ok. I also modified an oil filler cap with a bent filler tube. When you lock in the cap the filler tube is at a good angle to use. I just drilled out the cap and pressed in a bent plastic pipe. Hope this helps you.
Old Aug 23, 2004 | 09:44 PM
psyche's Avatar
psyche
I'm a little confused,do you have a funnel that is in a drilled cap? If so, that would leave it open. But after thinking about this problem, I wonder if you can just turn the pipe 180 degrees so it points more up and then try to mount the bracket somewhere? I'll have a look at that soon.
