Bronco II Ford Bronco II
4wd check?
Old Aug 22, 2004 | 10:29 AM
CryHavoc's Avatar
CryHavoc
4wd check?
I just bought a kind of beat up 88 Bronco II. The guy told me it has been over 5 years since he used the 4wd. How can I tell if it is ok, or safe to use? Is there something I can check myself or do I need to take it to a shop?
I do not know much about it as I have never had a 4wd vehicle before.
Many thanks!
Old Aug 22, 2004 | 06:57 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!!
You only want to use 4wd in snow or off road, I would just give it a try.
Old Aug 23, 2004 | 11:12 AM
mrshorty's Avatar
mrshorty
A couple of ideas for testing.
Like Ken00 said, engage the 4WD and see if you get both front and rear pulling.
Alternatively, jack up the truck so at least one front and one rear are off the ground. Engage the 4WD, and see if both the front and rear tires spin. CAUTION: Do this carefully so you don't have your BII jump through the back of your garage!!
You should have indicator lights on the dash that, if they are working, should indicate what position the transfer case is in.
Do you have manual or electric shift? Manual or auto hubs?
Old Aug 23, 2004 | 11:26 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Exclamation
Mrshoryt I would get all 4 wheel off the ground to check the 4 wheel drive system.I know that most of the BII came with open f/r gears but there might be a chance the rear is a LS or locked by previces owner.Dont need him to run it through the wall or door .
Old Aug 23, 2004 | 11:55 AM
mrshorty's Avatar
mrshorty
You are correct, I was assuming either open differentials or limited slips (My LS's aren't strong enough to jump the trucks off of jack stands). If it had a locker in it, then you would want both wheels on that axle off of the ground.
Old Aug 23, 2004 | 01:42 PM
CryHavoc's Avatar
CryHavoc
They are manual hubs (I guess, you have to lock something on the front wheel) and I am not sure but I guess the shift is manual too. There is a small stick next to my shifter that says 2wdH 4wdH 4wdL
Old Aug 23, 2004 | 11:03 PM
mrshorty's Avatar
mrshorty
Then you have manual shift and manual hubs. Odds are good that it works, then; there are very few problems with the manual shift/manual hub combination. Only trouble I've had was binding from running mismatched tires.
Old Aug 23, 2004 | 11:06 PM
rebocardo's Avatar
rebocardo
Go into a parking lot when it is pouring rain, lock the hubs, put it into 4H, turn the wheel slightly to the right and give it a little gas. If you stick your head slightly out the window you should see the wheel throw up water. This works best in mud as a test, though a puddle is okay too. Then unlock and see the difference. It will pour off the tire, but, not be thrown up.
Or
Engine off. Set the parking brake, block/chock the rear axle - front and back of both tires, put transmission in N and transfer case in N, lock both hubs, jack up front axle, turn one tire by hand, other should spin (usually backwards from the other one), now turn the front driveshaft by hand, should spin easy. Put transfer case in 4h. Driveshaft should be hard to turn, one front wheel should spin. Put transmission in drive, now front drivehshaft should be impossible to spin.
Old Sep 2, 2004 | 05:37 PM
suzie2's Avatar
suzie2
Question A similar problem with the hi-low shift on an 87 BII
I am experiencing a similar problem with an 87' Bronco II that someone gave me.
I can't get the the low range gears for the 4wd to engage. ( either 2 or 4 ) 2High and 4High go in just fine.
I can hear the gears just missing eachother when I engage the clutch ( grinding) . My BII is also manual shift w/od and manual locking hubs.
Is there an adjustment for the 4wd gears? What needs to be done?
Thanks
( I hope I posted this in the right place)
Suzie
Old Sep 3, 2004 | 08:15 PM
Single-Point's Avatar
Single-Point
Grinding gears
Have a look at the bushings on the shift linkage. If they are worn, it might not shift into 4WD
Good luck
LaSlw.4
1997 - 2003 F150
Feb 11, 2014 08:59 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Apr 29, 2012 07:41 PM
khadma
19
Nov 18, 2011 07:23 AM
Ipukeonnonfords
Aug 19, 2009 10:16 AM
026TB4U
May 13, 2005 11:03 AM
