Painted Flares vs. Tire Spray
I painted my bushwacker fender flares today and could not be happier with how the paint looks. I used Martin Senour AE without a hardner. The only thing I'm concerned with now is if debris flying off the tires will slowly sandblast the paint off. Has anyone had this happen? If so, I was thinking of adding some clear vinyl film on the inside edges of the flares. Thanks for your help.
if you did not use a hardner in the clear coat it will eventually get rock chips. the clear vinyl film would be a good idea. but i would wait till after the paint cures for a while cause that vinyl might hold the fumes in and might cause it to haze. best bet would be to clear over a couple coats with hardner in it or get some gravel guard which is like a very hard clear.
