Codes Again
Old Aug 21, 2004 | 10:20 PM
Firefighter8-1's Avatar
Firefighter8-1
Codes Again
P0171 - System Too Lean Bank 1
P0401 - Insufficient EGR Flow
Im lost as how to how to fix these codes. theyve both been present since i bought the truck and ive already replaced both upstream o2 sensors, cleaned the egr valve itself, replaced the egr tube, cleaned the egr port on the intake, cleaned the throttle body and intake as well. im lost now as to what to do, any help is appreciated.
This is what ive come up with after researching a little deeper:
P0171
Check PCV hoses for leaks
Clean MAF sensor
P0401
Replace Fuel Filter
Replace DPFE sensor
Old Aug 21, 2004 | 10:35 PM
Shadow Wolf's Avatar
Shadow Wolf
Have you ever erased the codes?
Old Aug 21, 2004 | 10:36 PM
Firefighter8-1
plenty of times, they keep coming back
Old Aug 21, 2004 | 10:49 PM
Shadow Wolf
Try some fuel injector/system cleaner. You may have a clogged injector. As for the EGR problem, check your solenoid and any vacuum lines going to it.
Old Sep 19, 2004 | 03:20 PM
g0ldrush's Avatar
g0ldrush
clean IAC maybe gummed oput
