check engine
Old Aug 21, 2004 | 09:36 PM
1984 f-250's Avatar
1984 f-250
Unhappy check engine
the check engine light turnes on for a mintue or two and then turns off on my 92 explorer. I looked at everything i could and everything checks out fine. i notice it turning on while going around corners, does anybody have any ideas what it might be?
Old Aug 23, 2004 | 11:36 AM
mrshorty's Avatar
mrshorty
What continuous memory codes do you get? Any KOEO or KOER codes?
Old Aug 23, 2004 | 12:06 PM
1984 f-250's Avatar
1984 f-250
Since the light randomly stays on for 30-60 seconds i have not been able to pull a code. the rabs computer does not store the codes so the code has to be pulled with the check engine light on.
Old Aug 23, 2004 | 11:18 PM
mrshorty's Avatar
mrshorty
I'm getting conflicting signals. Which light is coming on: the RABS light or the check engine light? It is true that the RABS system doesn't have a memory in it to store codes. The check engine light is wired into the EEC-IV (engine management) system, and doesn't have anything to do with the RABS system. The EEC-IV computer does have a memory that will hold codes for later retrieval.
Old Aug 24, 2004 | 11:12 AM
1984 f-250's Avatar
1984 f-250
the check engine light comes on
Old Aug 25, 2004 | 10:37 AM
mrshorty's Avatar
mrshorty
In that case, there should be some kind of code stored in the EEC-IV continuous memory. There may also be some KOEO or KOER hard fault codes. In any case, the next step is to pull the codes and see what comes up.
