Engine stalling
Old Aug 20, 2004 | 11:36 PM
duback66's Avatar
duback66
Engine stalling
My 89 300-I6 has started stalling when I come to a stop sometimes. It always starts right back up but sometimes when I come to a stop it either acts like it's going to die or does. What would be the most likely culprit to look at?
Old Aug 21, 2004 | 02:44 AM
fordflaresides's Avatar
fordflaresides
First things first, see if it pulls up any codes. A few quickies to check would be ignition components.
Old Aug 21, 2004 | 11:25 AM
duback66's Avatar
duback66
I did the code thing the way I understand it and here is what I got.
On the firt set of codes I got three flashes, pause and two flashes. Then a longer pause and then six flashes and seven flashes. I assume this is codes 32 and 67 for the first test.
There was a long pause then it flashes the code 32 again without the 67.
What do these numbers mean and could this be causing the stalling? Thanks
