Look Ma No Headlights
Old Aug 20, 2004 | 09:33 PM
hokeypokey31's Avatar
hokeypokey31
Well 2 nights ago my headlights worked just fine. Matter of fact I used them to illuminate the yard while I worked on another vehicle. Tonight I went and started the old beast up(1980 F-150 4WD) was going to take it for a little drive. I went to turn the lights on and nothing happened whatsoever. No dash lights, no headlights, no parking lights, nada but I still have turn signals, backup lights and brake lights. Any help on what could be the problem would be greatly appreciated.
Old Aug 20, 2004 | 10:27 PM
Garland's Avatar
Garland
Check and replace all bad fuses in the fuse panel and PDC related to your problem, if that doesnt work you probably have a bad switch.
Old Aug 20, 2004 | 10:30 PM
Garland's Avatar
Garland
It sounds like a bad/disconnected switch, everything that isnt working is wired through the headlight switch, and all the exterior lights that are working aren't on that switch.
