need trans code& axle code
Old Aug 20, 2004 | 09:31 PM
lrd56's Avatar
lrd56
Talking need trans code& axle code
i put my 86 f250 back together .the trans code is f.the axle code is 29.the spring code is b6.i dont know what these codes mean.
any help would be appreciated
lrd56 a happy dinosaur
ps i know the rear axle is a dana 61 .is it a good rear axle.
Old Aug 20, 2004 | 11:00 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Axle code 29 is a 3.55 ratio with open differential.
Old Aug 21, 2004 | 05:27 AM
ludis's Avatar
ludis
Transmission code F is a Borg Warner T18.
Old Oct 2, 2004 | 04:13 PM
natewill's Avatar
natewill
rear axle identification
Okay, my rear diff door code is '25', and my transmission code is 'M'. And to get even more specific, my rear housing tag is as follows: 2 V 110 C 1 10 10 2 9C21. What do I have, and how do you guys know all this stuff? Is there a database somewhere or something? BTW, it's a 1989 F250 4X4. Thanks.
Old Oct 4, 2004 | 11:14 PM
SoCalDesertRider
Code 25 is a 4.10 ratio. Looks like your axle has an open differential. The axle should be a Ford/Sterling 10.25" semi-float, although I think some of the numbers listed may be mis-copied from the axle tag. Axle codes are listed in the 'tech articles' section of this website under 'axle decoders'. Not sure on the trans code, sorry.
