1978 - 1996 Big Bronco
air tubes
Old Aug 20, 2004 | 12:26 PM
jason86's Avatar
jason86
air tubes
Due to emissions I had to replace the cats on my '86 Bronco. I took a y-pipe from an '88. Can anyone tell me where the air tube connects to? I can't see anything disconnected on my bronco behind the air pump.
THANKS!
Old Aug 20, 2004 | 12:43 PM
bronco5.8's Avatar
bronco5.8
That tube connects the outlet from the air pump and into the catalytic convertor. There should be an emissions diagram under your hood that tells you where everything goes.
Warr
Old Aug 20, 2004 | 12:50 PM
custom88's Avatar
custom88
Into the cat.
I have an 88" 4.9L inline 6 EFI. The air pump feeds into the forward cat. via a rubber hose and a nipple on the cat.
Old Aug 20, 2004 | 02:23 PM
jason86's Avatar
jason86
BTW I have a 302 EFI.
Would it be bad to run it without that tube connected?
Thanks for the help!
Old Aug 20, 2004 | 02:53 PM
bronco5.8's Avatar
bronco5.8
That added air helps the cat(s) burn up the raw fuel coming out of the exhaust. This will result in lower emission readings.
Warr
Old Aug 20, 2004 | 02:54 PM
MatthewC's Avatar
MatthewC
Nope, had mine rot off from my 4.9 efi, and never would have known it until I happened to see it.
-Matt.
Old Aug 20, 2004 | 04:53 PM
brokebronco's Avatar
brokebronco
THANKS!
The air tubes mount to the rear of the heads on the 86. You will need to remount them there to keep it emmisions leagal.
Chris
Old Aug 20, 2004 | 08:21 PM
Cloim's Avatar
Cloim
Air from air pump goes through some valves and t's.
There is a pipe connecting to the rear of the heads.
There is also a pipe leading to the cats.
On the factory setup ('86 302) the the pipe connects to the exhaust between the two cats.
The added air helps the second cat, but hurts the first cat. Aftermarket cats designed for air injection should have a connection on the cat for the pipe.
Old Aug 25, 2004 | 08:13 AM
jason86's Avatar
jason86
I see the pipe connecting the rear of the heads. the previous owner used a piece of heater hose connecting that pipe to the air valve behind the air pump. Should I "t" into that?
thanks
