Modular V10 (6.8l)
NO Start Problem.
Old Aug 20, 2004 | 03:05 AM
wardenxvx's Avatar
wardenxvx
NO Start Problem.
At work i have a 1999 E-450 cube truck with a V10 coil on plug ignition system. Recently the truck broke down with a no start situation..
Diagnosed a bad fuel pump.. replaced it with a new one.. still no start. no codes in memory no Koeo codes..
Checked spark.. Checked pressure of fuel 36psi.. went threw the no start pinpoint test came up with clogged exhaust.. i removed the cat and left it open headers.. no start..
i replaced teh crank sensor.. still no start..
decided i will force it to start using stater fluid and TB cleaner.. got it running.. no codes came up.. when you would hit the gas it would first stumble like it would choke out.. but the computer wont let it.. then it begins to accellerate very slowly... no audible misfire or anything. i let the truck run for a few hours. shut it off and it wouldnt start again.
I did observe while it was running then when it stuttered while on the gas the spark advance pid displayed 16300 which is way off the chart
i am completly lost and have no idea what else to check..
thanks for any input on this problem.
Old Aug 20, 2004 | 11:42 AM
jasontrucks76's Avatar
jasontrucks76
Three things are critical for ignition
1) fire
2) fuel
3) air
Sounds like you gave it fuel and you say you have spark, Than we need to look at air. I am not a mechanic and Im shure some one will speek up soon but If it were me I would look at the mass air flow sensor or something along those lines. These trucks are so complex it can get over my head real fast!
JT
Old Aug 20, 2004 | 02:55 PM
wardenxvx's Avatar
wardenxvx
i did swap a mass air sensor with one of our other e450 trucks.. that was also a v10 the only differerence the one with the no start problem is a 99 and the truck i used the mass air sensor was from a 2003...
Old Dec 25, 2004 | 08:41 PM
fordman1399's Avatar
fordman1399
my 99 v10 wont start ...took off snowplow, tried to start truck but no luck
Old Dec 25, 2004 | 08:49 PM
fordman1399
anyone have a no start issue with a v10...? i was driving the truck all day..decided to take the plow off.. did then tried to restart the truck and it turns over strong, but no fire...tried starting fluid in the throttle boddy....nothing at all...sounds like no spark right...well all the fuses are good too...... help!!
Old Dec 26, 2004 | 09:09 AM
Fredvon4's Avatar
Fredvon4
In the taking off the plow did you bang the truck hard against a tree or something. Could be the fuel sensor tripped and shut down the fuel pump.
Inside by passenger kick plate in the front is a fuel relay reset button that might need pushed.
Old Dec 26, 2004 | 09:34 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in this forum are very knowledgeable about these engines; they will eagerly help you…with your question.
To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE and Happy Holidays
Old Dec 26, 2004 | 08:03 PM
theswagg's Avatar
theswagg
The Fuel Filter?
When replacing the fuel pump you should always replace the fuel filter too. It sounds like it is plugged up. The motor will run as prescribed with a partially blocked filter. I know, it happened to me.
Old Jan 2, 2005 | 12:33 PM
fordman1399
thanks fredvon4.... i had the truck towed and they found a fuse blown under the dash that is for the pcm...somehow the plow shorted this fuse... thanks for your response
JMarsh
30
May 17, 2023 06:11 AM
Redneckfordf2502002
Jun 13, 2014 09:20 AM
dannyhess
13
Oct 25, 2012 11:25 PM
c3racer2000
1978 - 1996 Big Bronco
Oct 11, 2011 01:26 PM
joe.d
Aug 14, 2011 06:56 PM
