Trans/axle codes (what do I have?)
Old Aug 19, 2004 | 03:22 PM
Blasphemous's Avatar
Blasphemous
1984 Ford F150, 300 I6 Automatic and 2WD
Trans = W
Axle = 18
Old Aug 19, 2004 | 07:04 PM
82F100SWB's Avatar
82F100SWB
That truck came out of the factory with a C5 automatic, and a 3.08 geared 3750 GAWR Ford 8.8 rear end.
That's the first time I've seen anythng other than an 82-83 with a 3.8 V6 with a C5...
Old Aug 19, 2004 | 07:47 PM
Blasphemous
Is that good or bad? What was the other alternative to the C5?
Old Aug 19, 2004 | 07:56 PM
big hoss 29's Avatar
big hoss 29
The C-5 is really an oddball. It's ok if you don't abuse it, but the C-6 is the best choice if you want to put some power through it. The downside is that a built-up C-6 can cost you some serious $$. The next best would be a C-4 tranny. They're good tranny's and you can find them pretty cheap and make them handle some HP as well.
Old Aug 19, 2004 | 11:50 PM
hillbelly 351's Avatar
hillbelly 351
cutting into your thread
First off I would like to appologise for cutting into your thread. I an New to this! If a axle suffix of 18 is 3.08s than what would a 16 be??? in refrence to a 1985 canadian F-150. thank you
Old Aug 20, 2004 | 08:34 PM
82F100SWB's Avatar
82F100SWB
16 is a 9" with 3.50 gears
