Harmonic Vibration
Old Sep 30, 2000 | 11:23 PM
2000expltd's Avatar
2000expltd
Harmonic Vibration
My 2000 Explorer Limited has a harmonic vibration at 60 to 70 mph. It sounds and feels like heavy base from a stereo. I hear and feel it when the stereo of off or blasting away. You can see it in the rear view mirror, it vibrates at the same frequency as the vibration. It's blurry--then steady---then blurrry and so on.
Ford test drove and comfirmed the vibration. In fact they had another 2000 Explorer Limited with the exact same problem that they had taken apart the drive lines and replaced wheels/tires etc. and found nothing wrong. They called in the local Ford Tech Rep in with a vibration analyzer and she said it is the front differential. They replaced the other guys and say the problem is gone, so they will replace mine next week.
I am curious to know if any others are having similar problems. I do not think that some people can hear or feel this vibration. Some people riding with me do not hear or feel it---even when I point it out.
Old Oct 11, 2000 | 03:55 PM
dtucker1971's Avatar
dtucker1971
Harmonic Vibration
I have a similar problem with my 97 Eddie Bauer. It shakes/vibrates at 30-35 and then at aroun 60-65. The dealer did a vibration analysis and said it was within specs. I think it is coming from the front-end too. Would be curious what your result is so maybe I can seek some resolution to mine.
Thanks
DT
Old Oct 17, 2000 | 10:25 AM
dtucker1971
Harmonic Vibration
Any resolution yet?
Old Nov 23, 2000 | 10:25 AM
2000expltd's Avatar
2000expltd
Harmonic Vibration
Ford has installed a new front axel in my 2000 Explorer Ltd as well as the other Explorer I mentioned. We both reported vibrations after the new axels were installed, so the Ford Tech Rep reinstalled the vibration analyzer and re-tested each.
In the mean time he had hooked his equipment up to some other comparable Explorer' for some base line data. Turns out my Explorer is best one tested so far. And the other guy's is better than the base line vehicles...So they say. I still am getting the same vibration at 73 mph...however it is no were near as bad. The other guy main complaint according to Ford is rear view mirror vibation. They seem to think it is normal and OK.
Ford was very good about addressing this issue with us. They allowed me to inspect the gear set ( I am a gear cutter/inspector by trade) and both axels were sent back to Ford (and I assume Dana) for analysis.
BUT....BEWARE it's up to YOU to call them on it.
PS. My opinion(guess)is that the axel housing was not within machining tolerances which caused a slight mis-alignment in the gear set that caused the vibrations. The tooth contact pattern was very broad and washed out in the contact area.
Old Nov 23, 2000 | 11:48 AM
2000expltd's Avatar
2000expltd
Harmonic Vibration
